what is the angle drive fluid for?
Old Sep 10, 2011 | 02:24 PM
sportszillasheex's Avatar
Banned
Default what is the angle drive fluid for?
i bought angle drive fluid after being told it will work in the front gear case on my 500 sportsman. is that true or did the guy sell me the wrong stuff?
Old Sep 10, 2011 | 03:42 PM
Angle drive fluid is for front gear cases that have the awd in the hubs and also for rear differentials. You can substitute 80/90 GL5 rated gear oil if need be. Demand Drive Plus is for centralized gear cases with awd. Think you need to do some swapping out with the dealer and get the right fluid! DON'T put angle drive fluid in your front gear case! Way too thick! OPT
Old Sep 10, 2011 | 03:49 PM
Banned
well mine is an 07... i also have agl plus.. can i use that in the front as well as the rear?
Old Sep 10, 2011 | 09:26 PM
AGL (automatic gear case lube) is for the transmission only! You need the the demand drive plus fluid for the front gear case as its a thinner fluid designed for the awd system. OPT
Old Sep 10, 2011 | 09:29 PM
Banned
just as i figured, good ole north american rip off gave me the wrong stuff. "will this work in my front gear case on my 500 sportsman?" "YUP" and the hand goes out for the money. not only that for the angle drive fluid they way over charged me. atleast i got the tranny changed anyway..
Old Sep 10, 2011 | 09:43 PM
Could have been worse,you could have put that thick stuff in the front diff OPT
Old Sep 10, 2011 | 09:44 PM
Banned
good thing i was smart enough to look it up and do research!
Old Sep 10, 2011 | 11:22 PM
Spdecat's Avatar
All the info should be in your owners manual .
Old Sep 11, 2011 | 06:42 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if it's like me, i don't have an owners manual w/ this bike which sucks for sure.
Old Sep 11, 2011 | 09:54 AM
Spdecat's Avatar
I just can't figure out why so many owners don't have a owners manual . I keep mine in the back in a water proof bag . In it I wright down everything that I'v ever done to the machine at what miles and hours . It lists every part that was ever replaced , what fluids I used , when those fluids were changed , everything . The next owner will get all this info showing him the complete history of the machine . most owners of used machines should get this info . I don't understand why the owner who bought the machine new can't pass along the owners manual that goes with the machine .
