Sportman 500 HO
Old Sep 14, 2011 | 11:10 AM
bwilson's Avatar
Default Sportman 500 HO
I have a 500 Sportsman that the cooling fan will only work periodically. I can start it with a screwdriver and it will turn automatically (sometimes). when it does turn it is making a noisy sound. Is this just possibly dirt and debris or do i need a new fan motor? any possible remedies and what needs to be checked? I hate to buy a new part! Thanks for your help.
Old Sep 14, 2011 | 02:11 PM
Welcome to the forum! If you clean area around the blades and it still makes noise, runs slow,etc, and battery is ok,then probably time to replace.You can double check by running 12 volts directly to the fan and see if any change in the way it runs. OPT
Old Sep 14, 2011 | 07:21 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. it sounds like it could be the bearings are going in the fan motor if it has the correct voltage as mentioned by otp.
Old Sep 14, 2011 | 07:40 PM
Kerbbirds's Avatar
can buy a direct replacement on e-bay from Spal, look under polaris fans, much cheaper than dealer
Old Sep 15, 2011 | 09:03 AM
bwilson's Avatar
Thanks Guys! im not a very good at diagnosing problems. much appreciated!
Jazperman
Aug 7, 2016 08:12 PM
PatLac
Feb 25, 2004 03:14 AM
Grizzly2003
May 28, 2003 08:46 PM
Sportmanrider90
May 26, 2003 10:01 PM
Grizzly2003
Apr 22, 2003 06:30 AM
