27x12x12 rear 27x9x12 Blackwaters
How would this set up work on a Duse?
27x12x12 rear and 27x9x12 front blackwater XT tires on polished alluminum ITP magnums.
Will I lose anything(topend-lowend)?
Will it do any damage to cv joint's or any other parts?
On my Dodge,the 36's put a whooping on it
I also put this ? on the tires forum but I need an answer kinda fast.
Thanks
Thanks
Those are the tires I run on my Sportsman. I go through a lot more than I care to think about and I have not broken a single cv joint or axle...yet. I have had the tires for three years, and they not only do great in the mud but they also last a long time (assuming you don't ride on concrete). I still have 3/4 tread left on all tires, never a flat (15-20psi), and they will go through quite a lot. You may need a lift, however.
Pathfinder, the skinnier tires in the front definetely help out. Funny thing is, XT's have 6 plys and I think Vamps have 4. But the XT's weigh about 5 pounds less per tire (27x12x12). As far as 16" goes, I have a 2 3/4 collar and a lot of air pressure in the tires, and a little extra somethin' on the top of the spring perch( shock tower). I can't tell, though, I was sworn to secrecy
Progressive springs? Are they adjustable? If so, they may fit. The rear shouldn't be a problem.
If you are afraid of warranty voids from putting on a lift, I have heard of people putting spring rubbers in the coil springs. You can get 'em at Hi-Lo or similar auto parts store. Damn, another secret out the box...
Chasso
2) Chassis problems..
09-19-2015 03:06 AM
