Country style Plow vs. straight plow????
Old Nov 6, 2011 | 06:03 PM
cscotter's Avatar
Default Country style Plow vs. straight plow????
Getting ready to order a eagle plow blade for my sp800ox2
I think I want the 60" country (tapered or angled blade)
but wondered what people with experience think.
My understanding is at higher speed the angle of the blade will roll the snow away
There shouldnt be a disadvantage at slower speed I wouldnt think??????????
Old Nov 6, 2011 | 06:10 PM
irinman2424's Avatar
at slower speeds or smaller areas that you cant get up to speed it will not push it away at the speeds that you would be plowing with the 4 wheeler depending on how much you have to plow a flat blade should be fine the curved "country" blades are for longer drives that you can get the speed to "fling" it outa the way
Old Nov 6, 2011 | 06:20 PM
Oldsman67330's Avatar
I thought most of them could be run either straight or angled. I built mine from an old mower plow, and that's how I made it, I just pull a pin and turn the blade and drop the pin in a different hole.
P.S. If you are plowing with it angled and going very fast at all, keep an eye out for soft spots in the yard...I had a hole in the drive I had filled after the ground froze and it was still soft one day when I was plowing...laid the 450 Foreman over like a steer that got dogged at a rodeo!
Old Nov 6, 2011 | 06:21 PM
I was referring to the curve of the blade how its higher on one side than the other and curves around like a plow you see on the freeways
Old Nov 6, 2011 | 06:39 PM
cscotter's Avatar
so at the slower speeds it would still perform like a straight blade?? right??
That is my main concern
Is there any disadvantage to a country blade, when using at low speed??
Old Nov 6, 2011 | 06:41 PM
no there shouldnt be a disadvantage. the advantage is as stated if you have long drive you can get a little more speed and throw it other than that they will work the same
Old Nov 6, 2011 | 06:44 PM
cscotter's Avatar
sounds like a "win win" advantage to me if this is correct
If i can get the speed, it will roll it.
If i cant it will push the same as a straight blade.
Old Nov 6, 2011 | 09:18 PM
Raven95150's Avatar
Yep, if you have a long driveway I would definitely go with the tapered blade.
If you are just plowing a small area I would just go with a regular blade unless there is little or any price difference.
Joe454
Nov 20, 2020 01:19 PM
Alex G.
Sep 11, 2017 11:38 PM
tysonbully
Sep 28, 2015 02:30 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
