Bigger tires on sportsman
Old Nov 21, 2011 | 12:32 PM
ramdak's Avatar
Default Bigger tires on sportsman
Hey u guys I'm new and this site is awesome!
H
Just wanna know if I can run 27-10-12 in the front and 27-12-12 in the rear??? On my 2008 sportsman 800 HO
The rims are stock alloy 12x7.... And no lift kit....
Sorry if I spell like an A-hole... Bet u cant write in danish: Lol:: Lol:: Lol:
Old Nov 21, 2011 | 02:20 PM
awsume800efi's Avatar
nope the 27x10x12 in the front will not work, height wise you are fine it is the width that will get you. you either need offset rims or wheel spacers otherwise the tire will rub on the tie rod end. the rear ones will be fine with stock rims just not the front
Old Nov 21, 2011 | 02:25 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
27" tires will fit without a lift kit with no problems, however you'll definitely have problems up front with a 10" wide because of the tie rod ends. You will need to use wheel spacers or switch to an aftermarket wheel with a more negative offset. Some guy's flip the tie rod ends out at the wheel which will work, I just don't care for it.
Old Nov 21, 2011 | 02:29 PM
i flipped the tie rod on my 05 800 but that was with 28x9x12 tires i don't think even flipping the tie rod you will clear a 10" wide tire
Old Nov 21, 2011 | 04:53 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yea i agree in thinking it will work for a 9" wide tire, but i doubt a 10" in the tie rod trick. you really need differnt wheels or spacers as mentioned. i ran 27" xtr's on my 800 w/ no lift and it wasn't a problem.
Old Nov 21, 2011 | 08:59 PM
ftwflh's Avatar
You do know that if you go bigger on tires you will have to clutch for the size and weight difference.Mainlly just lighter on the secondary spring will do it.
Old Nov 22, 2011 | 04:45 PM
switzomatic's Avatar
I agree the fronts will need spacers or different rims. I always ran spacers on my 800's with no issues. Also agree on clutching it. Normal riding you will be fine without but if you get into the mud or pulling/hauling a clutch kit will save on the belt and improve low end torque. I always ran EPI big tire kits and had zero clutch/belt issues.
Old Nov 23, 2011 | 02:14 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i ran a differnt primary spring when i ran my 27" tires and had good results.
Old Nov 23, 2011 | 11:10 AM
ramdak's Avatar
Ok thz a lot for all your help: Thumbsup:
Old Nov 23, 2011 | 05:27 PM
Tonyxp's Avatar
On an 800 I don't think you will have to worry about re-clutching your machine with only 27's. May not be as snappy as with stockers but it isn't a must.
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
rcappie4
Jul 18, 2015 07:51 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
