2002 Polaris Trailblazer
Old Dec 6, 2011 | 01:22 PM
IronBear's Avatar
PF Powersports LLC
Default 2002 Polaris Trailblazer
Hello,
I may be trading an older Honda snowblower for a 2002 Polaris Trailblazer 250. Are these good machines? The guy said it's in great shape, just needs back brakes and a new pull starter.
Also, are there any performance mods that can be done to these machines and what do I need to look out for?
Thank you,
IronBear
Old Dec 6, 2011 | 01:59 PM
Just depends,does it run? Is electric start out too?? Depends on how its been treated,just like how you treated the Honda snow blower! They are the simplest of Polaris atv's and the little 250 will run for years if maintained properly. Electric starters are hard to get to(at the bottom of the engine) and all will eventually need at least piston and rings after awhile(don't last as long as 4-stroke engines) Just check it out and if possible check compression before you trade. You can do several mods to em from clutching,etc but they are not fire breathers to start out with.But can be fun and worth the trade! OPT
Old Dec 6, 2011 | 02:40 PM
IronBear's Avatar
PF Powersports LLC
Thanks Polaris Tech!
The machine has a new battery and the electric starter works flawlessly (according to the owner).
What should the compression be on this engine? I'm thinking it would be a good spare quad for my better half's nephew.
Old Dec 6, 2011 | 03:21 PM
Minimum of 100 psi JUST to be able to run properly,but 120-130 would be good! Around 135 psi or so on a new top end usually. OPT
Old Dec 6, 2011 | 06:00 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
may need new swing arm bushing, chain and spokets and tie rod ends. mormal wear items for something that has been ridden.
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
maxjung
Jul 13, 2015 05:11 PM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
