Canadian '03 325?
Hey guys my Polaris 325 doesnt have a model number and has a canadian manufacturing sticker on the front. Anybody else have this? also, I was wondering how many people have rear brake problems with theirs as I cant fix mine to save my life(I am only 16 and very inexperienced though)
Still should be the vin # etched on lower left frame below the a-arm. If you're having problems with the rear caliper just jack up the machine and turn the axle to see if it or the rotor might be bent.OR if you're talking about weak or no rear brakes,could be air in the lines or the small rear master cylinder may need replacing? OPT
Seem to remember my 01 trail boss had the Canadian sticker on it. FWIT, I still ordered any parts just and put used parts on it that were for the American model and they all worked fine.
OPT has the brakes covered. The rear on mine needed a bleeding it seemed about every other month.
Must have been the medieval model.
Just takes patience on bleeding the rear brakes because of the small master cylinder down by the brake pedal.If you just can't seem to get all the air out when you bleed it and can't get a firm brake pedal,might be time to replace it. The seals were bad about leaking and sucking in air. OPT
