Fixing camber problem??
Old Feb 27, 2012 | 09:05 PM
Cody_20's Avatar
Default Fixing camber problem??
I have a 06 sportsman 500 and it seems to have a camber problem. The tire lean out at the bottom (the part of the tire that touches the ground.) It has wore the inside of my tires out. Does anyone know how to fix this?
Old Feb 28, 2012 | 08:20 AM
Common problem as they get a little older and you can try heavy duty springs,or spring spacers as some have done to help straighten it up. Look at the "sticky"posts in the expert section about spacers on the springs. OPT
Old Mar 1, 2012 | 10:17 AM
TLC's Avatar
TLC
Is your rear springs set up to the stiffest setting yet?, if not give them a few more turns to stiffen the rear up.
Jmuddin284
Jan 19, 2026 07:16 AM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
sara durrant
Jul 6, 2015 05:32 PM
traumajunkie
Jul 5, 2015 03:03 PM
