help sportman 500 no power
If you haven't pulled the recoil and checked the stator and pulse coil for mud,dirt,etc wouldn't take long to check this along with checking stator and pulse coil resistance specs. Don't hold me to it but the pulse coil white and white/red wires leading to the cdi should be around 97 ohms + or - 20% and the stator red and red/black OR red and green?? should ohm out at 446 ohms + or - 20% also. Plus have you made sure your fuel isn't water contaminated or old? Fresh fuel? Good fuel flow to carb? Clean air filter,etc??? OPT
MeadowlarkFarm
11-27-2019 08:40 PM
