No spark! 6 yr olds driving me nuts
Was stator aftermarket OR oem Polaris? Have had some members have problems with after market ones. Stators were the biggest problem shorting out,didn't replace many cdis or coils(if any?) Did have a few resistor plug caps bad. You can pull the cap off and check the bare wire against the engine for spark. Plus did you check the safety tether switch? You can tie both wires together temporarily to see if you have spark and eliminate this as the problem. OPT
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
Schneider
06-04-2015 11:37 AM
