HELP! 2008 sportsman 500 HO carb. over charging
Old May 22, 2012 | 04:52 PM
This model should have all the grounds on the left frame just in front of the battery then! It's gradually coming back to me as I get the earlier models out of my brain! Still think you have a bad control module from the very start!! Especially if it's charging up to 17 plus volts! Can suck that new battery dry from overheating if you don't change it. OPT
Old May 22, 2012 | 05:20 PM
gixxerone's Avatar
Its brand new right from polaris warehouse.....they said no warranty when i bought it...now what do i do? Thank you for all your help.
Could it be the black box (cdi) above the ecm?
Old May 22, 2012 | 06:16 PM
Nope, the cdi just handles ignition. Think you just got a bad control module. Plus makes it even worse if you can't return it since you bought it online. .This is probably one of the few times getting it from a dealer would have helped. A good one would have replaced it for you. OPT
Old May 22, 2012 | 07:04 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I had the same problem with my 07 a couple years ago. May not be your problem but check this out. http://forums.atvconnection.com/pola...rcharging.html After having the polaris mechanic double check my stator he found a short on one of the three legs of the stator which caused the over charge situation. He also stated it was a little strange it was over charging instead of not putting out enough voltage but it can happen. The new stator fixed the issue and not one more problem since.
Old May 22, 2012 | 08:55 PM
  #15
gixxerone's Avatar
Thank you for the input, deff. something that i thought was working normal.
Cole Hadden
Jun 15, 2025 09:05 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
GregM
Jul 29, 2015 09:41 PM
200es
Jul 19, 2015 04:50 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
