07 Sportsamn 800 rear drive shaft
Old May 22, 2012 | 08:01 PM
HaydenS's Avatar
Default 07 Sportsamn 800 rear drive shaft
The split pin came out of my drive shaft and cut a moon shaped hole in my tranny. Has anyone ever seen this before. 159 hrs and 403 miles only
Old May 23, 2012 | 08:47 AM
DELUX500EFI's Avatar
BUY AMERICAN!
Yep had that happen to my 2002 Sportsman 700..Pulled tanny and had it welded and replaced pin with a stainless bolt..No more problems..
Old May 23, 2012 | 09:39 AM
Same thing here! Had a 700 brought in for making a grinding noise,spring pin had started to come out and was grinding against the transmission case. Put a bolt and nut on it also instead of a new pin(cut off the excess bolt and ground flat so even the nut wouldn't come off) because of customer's fear it would happen again. Didn't grind all the way into the gear case though. Caught it in time. OPT
Old May 23, 2012 | 08:21 PM
gomer4877's Avatar
check the u-joints on the rear drive shaft, a bad u-joint will cause the pin to work its way out, i replaced the roll pin with a grade 8 bolt and self locking nut
Old May 24, 2012 | 12:42 AM
switzomatic's Avatar
Same happened to me with my first 800 popo(05). Luckily, dealer replaced tranny under warranty and have never used another rollpin again! Used shearbolt/nut from a simplicity snowblower on front/rear shafts on every popo since with zero issues.
rcappie4
Jul 18, 2015 07:51 AM
ghost civic
Jul 15, 2015 10:48 PM
joeyupton
Jul 14, 2015 11:51 AM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
