Hood Latch Vibrating Loose
I have an '07 Polaris Sportsman 700. After mounting a gas can to the hood I now have an issue with hood vibrating the latches open.
Any suggestions for replacement latches which either lock or require a two step process to open (ie: push in and turn)?
Thank you,
Merlin
Thank you,
Merlin
I have a rotopax mounted on my front lid 07 sp500 and have never had issues. Come to think of it, the latches are a little on the snug side because of the seal. Are you missing the seal or is it worn out? I could see vibrations causing the latches to turn without any tension on them, but the gas can shouldn't cause a problem.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
