Oil drain plug sealing washer??
I have a 2007 sportsman 800 x2. My maintenance manual says to install a new sealing washer on the drain Plug when doing a oil change. I did not see a washer on the plug when I drained the oil. All my other oil changes were done by the dealer. I don't know if it went down the drain pan. Or doesn't exist???
Any thoughts appreciated!
Thanks OPT. Actually this oil change is being done by me. First time. So it's my fault I didn't see the old washer disappear. I left the drain plug out and haven't filled it back up with oil yet. I did buy the oil change kit from the dealer today. It has 2 quarts of oil. The proper filter. And a little oil change reminder sticker that you can fill out. But not a sealing washer
