clutch needed for 2002 250 TB have ???
I need a new or good used clutch for my 2002 250 tb, my ? is what part #s will
work, partsland says that the 1990-1995 and some 96 & 97 used the part
#1321976 wide clutch, from 1998 on up used 1322682 narrow clutch & some
1996 & 1997 also. the 1322682 seems to be a # that polaris used other models
also. do the all 1322682 fit my tb & I might have to change the spring in it on some
of them? are all the shaft sizes the same? are the comet clutches a good option?
the #s & the years on ebay have been all over the place I don't want the get the
wrong clutch, what is my best bet? also whats up with the wide & narrow clutch
thanx for any & all help.
The 1322682 drive clutch is the one called for you Trail Boss 250. If you order a new one you would have to use your own spring and counter weights as they come with out em. If you order a clutch or parts other than this one make sure you could return it if it doesn't fit. OPT
applies anyway. some sellers have the 1322682 listed as wide some have them
as narrow do u know what the difference is? I am worried that if I get a wide sent
to me my clutch cover will not fit as there is about 3/8 inch clearance, Partsland has
mine listed as a narrow & I think all 1322682 are narrow, thanx for your help OPT.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
