Which Main Jet would YOU Use?
Old Mar 20, 2001 | 08:49 PM
ScrambledKiwi's Avatar
Hi
I have a 400 Scrambler 4x4 with a few mods on it, and want to know what Main Jet I should use, as well as what setting I should use on the needle.
I have a HPD Pipe, Pro Design Cool Head, Wiseco Piston, HPD Reed Spacer, Delta V Force 2 Reeds and RCR air box mods. I have just installed the airbox mods and reeds and spacer. Currently I am running a 270 MJ and a 6CEY6 needle in the middle position. Most of my riding is at sea level.
Anyone out there that has been here before?
ScrambledKiwi
Old Mar 20, 2001 | 09:03 PM
NewDSLover's Avatar
Heres what I would do. 1st: Reeds & Spacer won't change your jets but the air box mods will. If your running a 270 w/ needle at middle. I would drop you needle down to the lowest setting and run a plug and mid throttle test(no full throttle), do this until you get your mid-throttle to clean running. Then up your main to a 300 or 310(K&N Power Kit will have these jet sizes). Run a plug test(and also listen for blubbering) and check for proper color. Do this until the color is light brown. Now if your in an area like I am, you will need to change these setting with the weather. Good Luck.
Old Mar 20, 2001 | 09:08 PM
Thanks DS Lover.
What is Blubbering, and I thought you had to do the main jet first, then work your way down to the Needle, then PJ, then mixture screw in that order to get settings correct.
You don't think the 300MJ is a bit rich do you? Most of my running is at sea level.
Old Mar 20, 2001 | 10:32 PM
Thor's Avatar
Blubbering is the sound of a two stroke engine when it is in the transitional stage between acceleration and deceleration. You know the bapapapapa sound that you hear when you try and hold the throttle steady under a light load.
Personally I have never been able to make the sound go away. They all do it at a certain rpms based upon the porting and reeds. (The only time my snowmobile gets close to eliminating the noise is when the temperature is -20 Fahrenheit.)
Anyway 300 does sound a little rich doesn't it?
Looks like you have been reading the internet pages on how to tune a CV carb by starting with the main jet and working backwards. I read that article myself I would have to agree. It works out great on two stroke motorcycles.
http://www.factorypro.com/tech/carbtun.html
With a piped and modified two stroke I would be very careful of leaning out the midrange too much as this is where the vast majority of two stroke engine seizures happen. Proceed with caution in that area. Too bad you do not have an exhaust gas analyzer guage which would measure air to fuel ratios.
http://www.scuderiaciriani.com/rx7/AF_meter.html
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
