View Poll Results: TrailBoss 250 help
help
100.00%
help
0%
Voters: 1. You may not vote on this poll
TrailBoss 250 help
Old Oct 13, 2012 | 02:03 AM
  #81
Set the meter on ohms value and measure the wires from the stator that lead into the cdi.Then test the coil. OPT
Old Oct 13, 2012 | 05:34 AM
  #82
jmoney1991's Avatar
Everything you listed tested good my moms friend knew and understood testing what you stated,
I have 120-130 compression
Blue spark its new plug
Fresh gas and carb is getn gas
New crank seals
Rebuilt carb and cleaned it 3 times
And won't start I'm to my point with this thing, whatelse is causing it not to start??
Old Oct 13, 2012 | 08:24 AM
  #83
New crank seals
The only other thing I can think of (IF I haven't already mentioned it) is to pull the black wire connection from the reverse limiter module located under the front panel. Its a square module with the only black wire on it. The other square module is the regulator/rectifier. PLUS make sure the thumb throttle doesn't have a lot of slack. Keep about 1/8" slack only! If neither of these sugestions help then I think you're finally at the point to where if you and your friend can't get it to run then it might be time to let someone who's experienced look at it. If "everything" is correct it should be running by now. Some where something isn't right.Maybe something you did or didn't do.You've done well and it's a learning experience for a 17 year old especially without a lot of tools and without a manual! We could keep this going for another 8 to 10 pages of dialog ,but I'm worn out same as you are.Someone experienced should be able to find what's wrong in a short period of time. OPT
Old Oct 13, 2012 | 07:03 PM
  #84
jmoney1991's Avatar
It fired up today ran good all day, by the way I'm 21 not 17 lol and if u were wore out u didn't have to post anything if ur wore out helping people then u should get off the computer or phone whatever u use lol....but hey thanks anyways sorry to wear u out when this site is to help people and get advice
Old Oct 13, 2012 | 07:22 PM
  #85
IF you'd gotten a manual,looked carefully at the links I posted as I suggested on the FIRST page of comments,8 pages of back and forth comments wouldn't have been necessary!!! Plus you never even bothered to look at your engine model and design long enough that I posted links for you,when you asked questions like "Does the 250 have a cam chain?" Whether your 21 or 17 doesn't matter to me. You've already showed you're maturity level to the entire forum! I'm here to help those whom I can and am able to help. I'm not here to be chastised by someone that won't listen. Feel free to visit other forums son and see how far you get with that attitude. OPT
Old Oct 13, 2012 | 07:25 PM
  #86
jmoney1991's Avatar
Lol u have the attitude dumbass **** off I don't need ur help so go **** your self old fart
Old Oct 13, 2012 | 08:36 PM
  #87
jmoney1991's Avatar
Old Sep 17, 2013 | 07:55 PM
  #88
Ted.k's Avatar
Default OPT? are you still available to lend a hand with a similar issue as posted here?
im having some similar issues and have a couple off concerns id like to ask about. I read through this entire thread and I was just amazed with how much patience and dedication you had throughout, and I have to say, as I neared the end and read how much your skill and knowledge was unappreciated I was at a loss for words. unreal and sorry for that. I assure you any knowledge you can share with me will be more than greatly appreciated. thank you. im new here so I have to mouse around a bit and learn how I will be notified if you respond. I have also sent you a friend request, thanks in advance.
Old Sep 18, 2013 | 07:00 AM
  #89
I'm here to help those that need or want help the same as many others on the forum are.What one person doesn't know,someone else will usually have an answer.. Just state your problems in detail as much as you can on your machine. Year, model, symptoms,etc and hopefully you can get some good tips and advise.
Saw your other post,sounds like you have things pretty well under control. For any replies post in one section or the other not both,gets confusing!
Last edited by old polaris tech; Sep 18, 2013 at 08:04 AM. Reason: Saw your other post!!
Old Sep 20, 2013 | 12:02 PM
  #90
Ted.k's Avatar
no problem. thanks
68_327_c20
Nov 25, 2023 12:26 PM
Magistar
Apr 13, 2023 04:39 AM
Myronh
Sep 8, 2015 11:27 AM
binky79
Jul 30, 2015 06:37 PM
2000Polaris
Sep 13, 2000 10:22 PM
