2012 Sportsman throttle issues
Old Oct 8, 2012 | 02:32 PM
Stephen R's Avatar
Default 2012 Sportsman throttle issues
Hi everybody im new to this but i got a 2012 polaris sportsman 500 HO and it has a lot of play in the throttle. It wont run or start unless im pressing the throttle. The throttle lever also has play up and down, I dont know if there is a screw that fell out or what happened. I tried to tighten the throttle cable adjustment and it didnt change anything. Any help or advise would be appreciated.
Old Oct 8, 2012 | 02:47 PM
WilliamBos's Avatar
Any warranty left? Send me a PM with your email address, and I will send you a service manual.
Old Oct 8, 2012 | 03:18 PM
Just pop the throttle housing cap off with a screw driver and see if the thumb lever screw is still in place and the etc switch and cable are working, the cable moving along with the etc contact points opening up. Adjust the thumb lever slack to 1/8" max. Any looser and the etc contact points will touch not allowing the atv to start unless the throttle is moved. OPT
Old Oct 8, 2012 | 04:17 PM
Stephen R's Avatar
Thanks guys I fianlly got the guts to pop off the throttle housing cap ( i was afriad to mess it up) only to find all of the play in the throttle was because most of the plastic compontes were cracked or completley broken thanks for the help. Now i just have to hope my warranty covers it
Old Oct 8, 2012 | 06:31 PM
As long as it wasn't wrecked and still under warranty, shouldn't be a problem on getting it replaced. OPT
chinkapin
Jul 14, 2016 06:58 AM
RticKwad
12
Jul 19, 2015 12:22 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
