info on tires and rims
Old Jan 28, 2013 | 12:05 PM
skull246's Avatar
Default info on tires and rims
i am going to get rid of my stock tires and rims , so what i want to know is what size rims and and tires i can go with without lifting it up, goin on a 2006 polaris sportman 500 HO efi
Old Jan 29, 2013 | 08:50 AM
skull246's Avatar
can i go 14 rims and 27 tires with out rubbing on anything
Old Jan 30, 2013 | 06:46 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Will fit fine. the big thing is, you have to watch the width on the front tires. 9" wide is as wide as you dare go unless your using rims with a greater offset than the oem.
Old Jan 30, 2013 | 09:17 AM
TLC's Avatar
TLC
Rims have nothing to do with much, 10" rims with 27" tires are as large a 14" rims with 27" tires. Just the tire sidewall profile height changes.
Id rather have 12" rims then 14", there more tire sidewall to get though before that rock hits that rim edge.
Lower profile tires on a ATV just can,t be good. Looks good on a sports car though.
Old Jan 31, 2013 | 01:26 AM
switzomatic's Avatar
27's should fit fine and, as mentioned by others, going wider up front will require different offset rims or spacers. I agree with TLC on sticking with 12" rims. Unless your racing around where you'd want less tire roll on corners all the 14" rims are good for is looks. Much better ride on 12"s.
Old Feb 1, 2013 | 09:05 AM
SOLOLUCKY's Avatar
IF you have 12's on it stick with 12's...cheaper also. bt if you have 14's stock then you are probably obligated to stick with 14's...my 550xp had 14's stock and there is NO WAY 12's would ever fit due to the big brake rotors.
Old Feb 2, 2013 | 01:54 PM
skull246's Avatar
i think i am going to go with the Interco reptile in 26 inch and itp 12 inch rims
Old Feb 3, 2013 | 01:53 AM
Check out the STI HD Beadlocks. Got mine from discountutvtire.com for $330 shipped and they're pretty awesome!
Axl_Z
Mar 9, 2025 11:14 PM
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
TLC
Sep 5, 2015 12:49 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
