4 Wheel Drive?
Old Feb 13, 2013 | 02:49 PM
McBeezy23's Avatar
Default 4 Wheel Drive?
When I engage four wheel drive only the front left wheel is spinning. I look at the axle inside the wheel on the right side and it looks like the shaft is spinning but not the wheel. Any ideas? It's a 1997 Polaris sportsman 400 4x4 2 stroke.
Old Feb 13, 2013 | 02:56 PM
If you haven't changed hub fluid,you might try that first. If it doesn't help check that you have both small awd connectors plugged in that go to the struts. Located under the front panel. Just trace the strut wiring up to the connectors. If none of this helps you may need to check out the mechanical parts in the hub. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
cody500ho
14
Aug 14, 2015 05:03 PM
toonces
Aug 5, 2015 05:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
