voltage regulator??
Old Feb 21, 2013 | 05:12 PM
Wenty's Avatar
Default voltage regulator??
98 explorer 400...battery was shot...replaced with a fresh battery. Ran the ATV for a few hours...next day frozen dead battery. It was a cheap Wally world battery...figured it was just.junk. purchased a yuasa (sp?)
Ran great...next day...dead! Just put a multi meter on it after a fresh charge. 12v. Fire it up and get 14v...give it some gas and get 17.5v!
I assume its the.voltage regulator? Thought?
Old Feb 21, 2013 | 06:07 PM
Regulator/rectifier's overcharging the battery. Batteries will heat up and bubble out the vent tube if a conventional battery or will just dry up and short the cells out in maintenance free batteries. Have had that happen several times. They can under charge or overcharge.Here's one place to get a new one. http://www.regulatorrectifier.com/catalog/Polaris-67
Here's the other one. http://www.psep.biz/store/polaris_at..._regulator.htm
According to the manual you can test the yellow and yellow/red wires from the stator.Set the meter on amps and recoil start only and have at an idle. Should be around 5 amps.
Old Feb 23, 2013 | 05:46 PM
Wenty's Avatar
Thanks opt.
Did some trouble shooting today...found the connector w/ red/brown wire to be the issue. Both corroded...red connection corroded through and broke. A few new connectors and some shrink tube... good to go. 13/14 volts at idle/3k.
Old Feb 23, 2013 | 07:23 PM
Originally Posted by Wenty
Thanks opt.
Strange? Usually this would cause an under or no charge condition back to the battery. As long as you found the problem and it's charging correctly that's all that matters! Good luck.
Joe454
Nov 20, 2020 01:19 PM
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
