250 trail boss
Old Feb 25, 2013 | 03:44 AM
Pkthomason's Avatar
Default 250 trail boss
Every time I load my 250 on a trailer and go somewhere and when I get ready to start it take forever to start and sometimes can't get it started its getting way to much gas and oil I beleave and is there something I can do to fix it took the carb off clean real good and justed the float arm I beleave that's the name got better feels like more power now but still doing it any help please tired of changeing plugs and ps y'all are awesome
Old Feb 25, 2013 | 07:33 AM
Fouling plugs is one sign of low compression and not just a carb/fuel issue. Get a good compression reading and that will tell you where you stand. If it's 100 psi or lower that could be the problem on hard starting and plug fouling.
Old Feb 25, 2013 | 07:39 AM
Pkthomason's Avatar
The plug is soaked but if I don't haul it on the trailer it want foul it out just does it when I put it on the trailer but I will try what u said to do
Old Feb 25, 2013 | 07:49 AM
Also on the two strokes it's best to turn the fuel valve off after use. You can have fuel dumped into the cylinder and will foul plugs also if the carb needle and seat are worn.
Old Feb 25, 2013 | 07:51 AM
Pkthomason's Avatar
I got to get that fixed it broke off on me I beleave that is it
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
awer1968
Sep 8, 2015 11:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
Canamaniac!
Sep 4, 2015 06:44 PM
