Magnum 500 rear disc brake
Hi everyone I cannot seem to figure out how to get the disc brake off of the axle. I have removed the axle nuts and removed the hub off the splines. There are 3 bolts that are hold the rotor onto an inner hub sorta thing. The bolts will not unscrew all the way because of the axle tube. I am hoping when I get the disc off I can than go ahead and slide the diff off. Any thoughts and suggestions on what I should be doing.
Can't remember all the models on disassembly ,but I think the snap ring #33 holds the drive shaft and must be pried out and down so the shaft can be pulled out from the right side.I might be wrong again? Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
SixSpeed5
8
Aug 2, 2015 05:38 PM
