Rear propshaft roll pin?
Old Mar 12, 2013 | 05:09 PM
WilliamBos's Avatar
Default Rear propshaft roll pin?
I saw the damage it can do to the trans case (on another forum...) if it comes out. Wears a hole in trans case.
Should I push it out and put a metric bolt with nylok nut (and locktite)?
Old Mar 12, 2013 | 05:25 PM
Very seldom do roll pins come out,but yes they can cause damage if they do and the owner doesn't catch it in time. If in doubt(or if a roll pin can move easily with a punch and hammer,just go to Ace hardware,etc and get a new one. The new one should take a lot of force to seat it in place. Plus you can take a dremel and slightly flatten both ends. It can still be removed later if necessary.
Old Mar 12, 2013 | 05:27 PM
WilliamBos's Avatar
Thanks OPT. Sounds like something else to keep an eye on. If it has not moved, I will leave it be.
Old Mar 12, 2013 | 07:23 PM
user493's Avatar
Moto Psycho
If you ever remove a roll pin you should replace it with a new one. When one comes lose I have to wonder if it was an old one that was reused.
Old Mar 14, 2013 | 12:18 AM
switzomatic's Avatar
Had major issues with that on my 05 800sp. Wrecked one tranny that my dealer thankfully replaced at no charge(was out of warranty). Kept a wary eye on them after that and both front and rear pins started working their way out again (caught before any damage). Replaced with a shear bolt/nylock nut and zero issues after.
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
Sep 9, 2015 10:56 AM
black_thunder
Sep 7, 2015 01:24 AM
lancemll88
Sep 6, 2015 03:03 AM
lancemll88
Sep 5, 2015 03:16 AM
