1997 explorer not charging
Old Apr 8, 2013 | 08:56 AM
markshop's Avatar
Default 1997 explorer not charging
What should the stator resistance be between the two yellow wires on a 1997 300 explorer 4x4 ? I checked they are not grounded out. No charge to battery. The reading I get seems to varies between .1 and .2 ohms
Old Apr 8, 2013 | 10:16 AM
Should read 0.3 between the Yellows and Yellow/red. No shorts to ground. You're with in the 20% range. Most times charging problem are the regulator/rectifier if the wires are connected properly to the regulator and since you have at least 0.2 reading on the stator wires, I'd replace the regulator. Polaris ATV Rectifier Regulator
Old Apr 8, 2013 | 11:48 AM
markshop's Avatar
Default explorer
Ok thanks Polaris tech. It seems we replaced the regulator just two years ago for the same problem. Is there something that could be taking it out? Also at the same time we replaced the radiator fan switch because it was on all the time. And the fan is on all the time again with the key on. Are they somehow related?
Old Apr 8, 2013 | 12:00 PM
No,they're not related as far as to what can happen between them. Regulators can go out at any time,plus the sensor on the radiator can to. The sensor has probably shorted out if the fan is on constantly. Just take it to any auto store and find a replacement instead of a high dollar Polaris sensor.Item #10 Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Apr 8, 2013 | 12:13 PM
markshop's Avatar
Ok thanks very much.
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
zPuls3
Sep 12, 2015 08:54 AM
