HD front springs or front shock spacer
Old May 6, 2013 | 12:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Originally Posted by Nelson86
How can I test to see if my shocks are going bad? I do have a winch mounted to the front which could be causing some squatting along with the springs being wore out as well.
you can see oil leaking out or they won't rebound or dampen correctly. most likely, the springs are weak. changing springs or adding spacers will help alot.
Old May 6, 2013 | 02:57 PM
jgar's Avatar
Originally Posted by TLC
My ATV ride really improved when the Warn Winch on my 500 fried. By the time I took off the steel mounting plate and winch it lighten the front end right up.
The winch and mounting plate is like riding around with a 45lb 10" cement block strapped on the front rack at all times.
Providing there are some extra lbs up front. How do the hd spring feel on the trail. Is it still a soft ride or do they slam you around more?
Bratman2
Aug 6, 2022 01:42 AM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
