changing the oil
Old Jul 28, 2013 | 04:10 PM
Originally Posted by shizcol
how do i check this? and is a valve adjustment hard to do on these machines? i dont know if it needs one but i would want to make sure.. cause i want this one to last me..
Not hard to do,but a couple of the valve cover 8mm bolts are hard to reach,but If I can do it with my big hands anyone can!If you have a Scrambler 500 and NOT a Sportsman 500 it is a little easier just to unbolt and raise the rear of the tank a little to remove the 8 bolts on the valve cover.Once the valve cover's off,remove the rectangle plate on the right side of the head held on by 5 bolts. Leave the spark plug in and just slowly pull the recoil rope until you see the intake valves go down and start to come up. When the cam sprocket index pin is straight up center of the head,this TDC. Valves can then be checked. Clearance is .006 intake and exhaust. Best to have two feeler gauges for the exhaust twin rocker arm especially if you have to adjust them. Here's a pic on the index pin and sprocket. Plus here's a link to a pdf manual that can help you on all service and repairs.http://gh-ftp.com/ORV%20Manuals/Pola...96%20-%202001/
Attached Thumbnails changing the oil-2011-05-21_125845_00_polaris_500_cam_timing.jpg
Old Jul 28, 2013 | 05:30 PM
shizcol's Avatar
wow thanks for the info.. its great being part of this forum.. awesome people here.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
