2005 Polaris Predator Reverse Switch Question
Old Aug 16, 2013 | 03:47 PM
MR Racing's Avatar
Default 2005 Polaris Predator Reverse Switch Question
I just go done rebuilding my 05 Predator. I was wondering exactly what the reverse switch/turn cable thingy (don't know technical name) does. I know reverse is all the way down and it will go into it and work fine without the cable. Is the cable a safety switch so it wont go into reverse while shifting down? Also where does it even hook up? I search my service manual back and forth with no luck. Any help is awesome. Thanks
Old Aug 16, 2013 | 04:54 PM
If you can hit reverse without turning the reverse lock out switch, then the switch may be faulty as it does show an updated part number. #23.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Didn't have any problems on any at the shop,but since it's changed part #'s for a reason,it might be a good idea to replace it,but I still think it's like the old Expedition 425 that you wont be able to engage reverse until the rpms drop to keep from any damage. Here's the reverse idle gear,reverse gear and shaft.#11 and #13.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Predator_500
Jun 13, 2015 03:01 PM
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
May 27, 2015 11:15 AM
