Oil filter for 2013 Polaris
where should I buy a oil filter? Is there any ones that are better than others.
My polaris is brand new i only have about 4 hours on it, 11 miles, and what oil should I use?
From what I have heard I should change oil and filter at 25 hours?
Is there any other maintenance that should be done?
Or shouldi just take it to Polaris and let them take care of it?
Thanks
Thanks
Different filters than can interchange with Polaris #3084963 oil filter.This is an excerpt from the link I posted at the bottom of the page.Look over the link,if you have different brands of motorcycles,atvs..
These Oil Filters
have 20 x 1.5mm threads,
14 psi by-pass valve,
anti-drain back valve,
2.3" O.D. gasket
2.5" to 3.5" long.
If you have the room, I recommend the longer filters.
Motorcycle Filters.
None are recommended.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
AC Delco PF2135
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
Recommended filters.
All have superior
filtering.
About 2.5 inches long.
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12.
Made by Champion.
Bosch 3300, about $6.
Made by Champion.
Wal-Mart SuperTech ST6607
Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10.
Made by Champion.
Bosch 3323, about $6.
Made By Champion.
WalMart SuperTech ST7317,
about $2. Made by Champion.
Automobile Filters,
about 2.5 inches long.
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters,
about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram Double Guard DG7317
Fram PH7317
Automobile Filters,
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Millard ML-3593
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
I'd change oil at 25 hours. Polaris uses a "standard size" filter that many different brands use and can cross over to many others brands of filters for motorcycles and atvs,Wix,Amsoil,Purolator,etc. In fact a 500 Sportsman filter can fit my old Honda Nighthawk. Look at list and the filter brand choices you have in place of the Polaris oil filter # 3084963. Motorcycle Oil Filter Cross Reference
These Oil Filters
2.3" O.D. gasket
2.5" to 3.5" long.
Motorcycle Filters.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
AC Delco PF2135
FRAM PH6017A
Honda 15410-MCJ-000
NAPA Gold 1358
STP SMO 17
WIX 51358
All have superior
filtering.
Made by Champion.
Made by Champion.
Made by Champion.
Made by Champion.
Made By Champion.
Automobile Filters,
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WIX 51365
Automobile Filters,
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Deutsch D-370
Fram PH7317
Automobile Filters,
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Millard ML-3593
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
changed filter and oil on 2013 polaris 500. I did not remove screen.I went for ride and machine kept stopping .I did the prime the oil pump thing and now it works good.Did I do any damage to my motor?????.
Screen shouldn't have been dirty,very few are if oil is changed regularly. As long as you drained the tank,the sump(8 ounces) and added 2 quarts of good synthetic oil,plus primed it(not really necessary to prime if you don't remove the screen) this shouldn't have caused it to stall. Make sure the thumb throttle has 1/8" slack only also or it can die at an idle if you have too much slack and the etc contacts in the throttle housing touch. As far as what caused it to stop and what if any damage has happened no one can tell.You say it's running good now.. Only way to tell is to drive it and see how it does.
