Sportsman 90 fuel or compression?
Old Mar 25, 2017 | 03:38 PM
  #21
Tsmothers's Avatar
I just replaced the cylinder head, rings and piston. So I don't think it would be that but I will check compression I am thinking it could be the seals. Thank you for the help
Old Mar 25, 2017 | 04:57 PM
  #22
LT80's Avatar
LT80 Expert
I agree w/OPT.
Curious, why did you do the new top end? Could the oil injection not be working?
Old Mar 25, 2017 | 08:14 PM
  #23
Tsmothers's Avatar
Default Won't start
I changed them because the people I got it from said the oil injection was not working but continued to keep putting regular gas it in so when I got opened up the the top end the rings was smoked so I changed it all rings,piston, and cylinder was running fine earlier now nothing
Old Mar 26, 2017 | 09:32 AM
  #24
LT80's Avatar
LT80 Expert
So did you fix or confirm that the injection is working? Run pre-mix ?
Old Mar 26, 2017 | 09:59 PM
  #25
Tsmothers's Avatar
Default Won't start
Running premix now
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
