2000 Polaris 500 cc HO Oil Change
Old Dec 16, 2013 | 09:54 AM
  #21
Polquad498's Avatar
Question You can see the crankcase bolt from
the right side looking thru the small hole for the manual rear brake. If you lay on your side there you can feel for the bolt and see a small portion of what you are doing thru that brake hole. I like to remove it and drain because it drains for a long time, like 20 mins, yes small amounts but its not a drop by drop thing, its a small thin steam for minutes, enough for a beer or two. I feel like this removes even more of the last small crud stuff.
OK here is a question for OPT: on an older machine ('98) that is new to me should i remove/clean the oil screen? I was thinking of doing it just this once. On my newer '10 sporty it can out clean as a whistle so i won't bother with it or the even crazier priming procedure.
Old Dec 16, 2013 | 10:54 AM
  #22
If you want to drain the sump that way it's fine. As far as the screen,if the machine is new to you then yes I'd pull the tank screen for peace of mind especially on the older models.Use teflon tape or liquid pipe sealant on the threads when reinstalling.Don't forget to clamp off the tank vent line close to the fitting when ready to restart so the oil pump can prime faster.Leave it clamped for a couple minutes then kill it. Most cases you'll hear a hiss of air from the line when you remove the vice grips.
Old Dec 16, 2013 | 12:47 PM
  #23
TLC's Avatar
TLC
I like the let the motor idle for 10 seconds to get that remaining engine crase oil out rather then using oil drain.
Its just so much easier and quicker.
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
