330 magnum help.... Electrical need help
Old Nov 25, 2013 | 05:14 PM
Then here's a cheap 5 buck service manual.2003 Polaris Magnum 330 Service Manual PDF Download
Old Nov 25, 2013 | 05:18 PM
MAGNUM330TROUBLE's Avatar
I got it downloading.. Thanks... I wish i wouldnt of opened this can of beans.. Anyway to test if bad ecu or ecm with voltmeter?
Old Nov 25, 2013 | 05:38 PM
Not really on the ecm,but look at chapter 10 pages 10-12.Shows the stator ac checks so you can eliminate it as a problem hopefully.
Old Nov 25, 2013 | 06:00 PM
Thank you much sir.. Im going to check that but its hard with working 7-6 with a youngin... But will definately keep you informed.... Also if stator is good would you fall back to a faulty ecm/ecu
Old Nov 25, 2013 | 06:11 PM
  #15
That would be my guess from the experience I've had with them.Plus here's a later model ecm that a member had that went south on him.
Attached Thumbnails 330 magnum help.... Electrical need help-img_20131123_103532.jpg
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Gwolf228
Feb 18, 2017 01:36 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
