2004.5 Sportsman 700 - Auxiliary Brake to Transmission Question
Old Feb 28, 2014 | 11:32 AM
easygoin43's Avatar
Default 2004.5 Sportsman 700 - Auxiliary Brake to Transmission Question
I was wondering if someone could tell me how the foot brake interphases with the transmission- when your supposed to push it down before you go in Reverse and Low.
Is there an electrical switch or mechanical thing that happens when the spring pulls the rod out of transmission by foot brake.
I have yet to get mine on the road but up on jack stands trying to determine how it functions.
The little rod only comes out about 1/4" when foor brake is pressed.
Thanks
Old Feb 28, 2014 | 11:51 AM
Just a mechanical plunger that locks out the gear selector in the transmission. Glad when they finally got rid of it as the spring would have a habit of vibrating off the foot brake pedal and you'd have to reattach it. Part #62 is the plunger, #9 is the gear selector. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Feb 28, 2014 | 12:14 PM
easygoin43's Avatar
Thank you Sir for the quick response..
Is there a way I could pull off the cover #3 or something easily to see if its working correctly, mine only comes out about 1/4". When I got this basket the guy had an allen wrench in the hole that is in the plunger, it may have gotten turned if that matters?
Thanks
Old Feb 28, 2014 | 12:37 PM
Her's a pic of a nasty one I found. Had a couple customers defeat the plunger. Can't remember what they did off hand.
Attached Thumbnails 2004.5 Sportsman 700 - Auxiliary Brake to Transmission Question-4-wheeler-trany-shifter-6-.jpg
Old Feb 28, 2014 | 01:20 PM
Kerbbirds's Avatar
Remove the spring, take a piece of wire and tie plunger down to the frame, works like it should without pushing brake.
Old Feb 28, 2014 | 01:47 PM
easygoin43's Avatar
Thanks for the pic OPT- Pictures worth a ton..
And thanks for the bypass technique..Kerbbirds
I will look into it now that I understand how it works..
Old Feb 28, 2014 | 02:07 PM
You can also unscrew the plunger assembly if you wish,match the thread pitch up at any hardware store and just install a small bolt and washer and do away with this system.Finally remembered what a couple guys did to their machines. The plunger was eliminated on the 2006 models.
toonces
Oct 16, 2019 12:11 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Shifts
Jul 3, 2015 07:59 AM
bikedad3
Jul 2, 2015 02:15 AM
scaldwellk
Jun 19, 2015 05:08 PM
