04 700 EFI Battery problem
Hello,
I have an 04 700 EFI the battery is a few years old so I wont be surprised if its dead, My question is Can I test the stator and voltage regulator by starting the machine and unhooking the battery? I did observe this summer that if the battery is unhooked it will idle but seems to die out when I give it gas. if it keeps running it means the stator and voltage regulator are good. same idea as testing the alternator on a car. Right now if I charge the battery it will start and run fine all day long ... but in two days if I go back the battery is dead. I just wanna do a test and see if its a stator problem, because if it is and the stator looks hard to get to like the stator on my Skidoo rev, I am gonna charge up the battery and go trade it in at the local stealer.
Thanks
Thanks
Do the voltage test first. Don,t get ripped off at a dealers. I have a $60 Walmart EverStart ATV battery in my Yamaha Grizzly that my Canadian Yamaha dealer wanted $160 for the OEM battery.
The Walmart Battery is starting great after 2 years.
I bought a Walmart battery that lasted 4 years in my 583 Ski-doo Grand Touring. I bought that battery for $40 in Michigan.
12v is 12v.
12v is 12v.
Hello,
Thanks
Thanks
Also invest in a float charger. They're under $10 at Harbor Freight and they always have coupons where you can get one for like $6. I keep them on my machines when not in use and can testify that it greatly extends battery life. An AGM or lithium ion battery for a replacement is a spendy option but well worth it. Last longer and more cranking amps than any oem out there.
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
