Trailblazer 250
#22
#25
A whole bunch of other models used the same style recoil assembly.
Usage : 3083924
Year Product Model Assembly
2006 ATV TRAIL BLAZER RECOIL STARTER - A06BA25CA (4999201499920149C09)
2005 ATV TRAIL BLAZER RECOIL STARTER - A05BA25CA/CB (4999201499920149C09)
2004 ATV A04BA25CA TRAIL BLAZER RECOIL STARTER - A04BA25CA/CB (4999201499920149C09)
2003 ATV TRAIL BLAZER 250 RECOIL STARTER - A03BA25CA/CB (4999201499920149C09)
2002 ATV TRAIL BLAZER RECOIL STARTER - A02BA25CA/CB/CD (4969896989C11)
2002 ATV TRAIL BLAZER FREEDOM RECOIL STARTER - A02BA25CA/CB/CD (4969896989C11)
2002 ATV XPLORER 4X4 RECOIL STARTER - A02CG25CA (4969856985C12)
2001 ATV XPLORER RECOIL STARTER - A01AG25CA (4963866386C013)
2001 ATV TRAIL BLAZER RECOIL STARTER - A01BA25CA (4963666366C012)
2000 ATV XPLORER RECOIL STARTER - A00AG25CA (4954865486C014)
2000 ATV TRAIL BLAZER RECOIL STARTER - A00BA25CA (4954825482C013)
1999 ATV TRAIL BOSS RECOIL STARTER - A99AA25CA (4949594959c011)
1999 ATV TRAIL BLAZER 250 RECOIL STARTER - A99BA25CA (4949574957c012)
1998 ATV TRAIL BLAZER RECOIL STARTER Trail Blazer W98BA25C (4945464546C011)
1998 ATV TRAIL BOSS RECOIL STARTER Trail Boss W98AA25C (4945314531C011)
1997 ATV TRAIL BLAZER RECOIL STARTER (BLAZER) Trail Blazer W97BA25C (4940124012D007)
1997 ATV SPORT 400L RECOIL STARTER (BLAZER) Trail Blazer W97BA25C (4940124012D007)
1997 ATV TRAIL BOSS RECOIL STARTER Trail Boss W97AA25C (4940574057C011)
1996 ATV TRAIL BLAZER ES RECOIL STARTER (BLAZER) - W967827 (4935863586D008)
1996 ATV SPORT 400L RECOIL STARTER (BLAZER) - W967827 (4935863586D008)
1996 ATV TRAIL BOSS RECOIL STARTER Trail Boss W968527 (4935883588C011)
1995 ATV TRAIL BOSS 250 RECOIL STARTER Trail Boss W958527 (4930323032C011)
1995 ATV TRAIL BLAZER RECOIL STARTER Trail Blazer W957221 (4930363036C010)
1994 ATV TRAIL BOSS RECOIL STARTER - W948527 (4926822682C009)
1994 ATV TRAIL BLAZER RECOIL STARTER Trail Blazer W947221 (4926832683C008)
1993 ATV 250 2X4 RECOIL STARTER - W937527 (4924022402c012)
1993 ATV 350L 2X4 RECOIL STARTER 2X4 350L W937539 (4924032403036A)
1993 ATV 250 4X4 RECOIL STARTER 4X4 250 W938127 (4924042404038A)
1993 ATV Euro 350L 4x4 RECOIL STARTER 4X4 350L S938139 (4924342434041A)
1993 ATV Euro 350L 4x4 RECOIL STARTER 4X4 350L W938139 (4924052405041A)
1993 ATV 350L 4X4 RECOIL STARTER 4X4 350L W938139 (4924052405041A)
1993 ATV 250 6X6 RECOIL STARTER 6X6 250 W938727 (4924092409046A)
1993 ATV Euro 350L 6x6 RECOIL STARTER 6X6 350L S938739 (4924362436049A)
1993 ATV Euro 350L 6x6 RECOIL STARTER 6X6 350L W938739 (4924062406048A)
1993 ATV 350L 6X6 RECOIL STARTER 6X6 350L W938739 (4924062406048A)
1993 ATV SPORTSMAN 4X4 RECOIL STARTER Sportsman 4X4 / W938039 (4926382638041A)
1993 ATV TRAIL BLAZER RECOIL STARTER Trail Blazer W937221 (4924082408032A)
1993 ATV TRAIL BOSS RECOIL STARTER Trail Boss W938527 (4924072407033A)
1992 ATV TRAIL BOSS 2X4 RECOIL STARTER ASSEMBLY 250 2X4/W927527 (4922862286039A)
1992 ATV TRAIL BOSS 4X4 RECOIL STARTER ASSEMBLY 250 4x4 / W928127 (4922872287D005)
1992 ATV BIG BOSS 4X6 RECOIL STARTER ASSEMBLY 250 4x6 / W928627 (4922902290045A)
1992 ATV Euro Big Boss 6x6 RECOIL STARTER ASSEMBLY 250 6x6 / W928727 (4922842284049A)
1992 ATV BIG BOSS 6X6 RECOIL STARTER ASSEMBLY 250 6x6 / W928727 (4922842284049A)
1992 ATV TRAIL BOSS 350L 2X4 RECOIL STARTER ASSEMBLY 350 2X4 / W927539 (4922882288038A)
1992 ATV Euro Trail Boss 4x4 RECOIL STARTER ASSEMBLY 350 4X4 / W928139 (4922832283044A)
1992 ATV TRAIL BOSS 350L 4X4 RECOIL STARTER ASSEMBLY 350 4X4 / W928139 (4922832283044A)
1992 ATV TRAIL BLAZER RECOIL STARTER ASSEMBLY Trail Blazer / W927221 (4922852285035A)
1992 ATV TRAIL BOSS 250 RECOIL STARTER ASSEMBLY Trail Boss / W928527 (4922892289039A)
1991 ATV TRAIL BOSS 4X4 RECOIL STARTER ASSEMBLY 250 4X4 - Update (4919791979047A)
Usage : 3083924
#26
Ok, what's the deal with the orange plastics? I can't seem to find them anywhere. What year(s) had orange plastics? I've seen them online and used that information to search in a parts diagram and I'm not finding orange anywhere. Is it only a certain year or model? I know they made a few different engine variant trailblazers but I'm having no luck here. Any help is appreciated. A stock part number would be great if anyone knows or has one, for both front and rear plastics.
#28
2005 Polaris Trail Blazer 250 Trailblazer Front Fender Plastics Orange 1 | eBay Only other thing I've found listed is for a "Cosmic Sun" for 2005 and 2006. Good luck if you can find this. More than likely NLA.
Usage : 2632993-496
2006 ATV SCRAMBLER 500 4X4 CAB, FRONT - A06BG50AA/FA (4999201549920154A03)
2005 ATV TRAIL BLAZER FRONT CAB - A05BA25CA/CB (4994739473A03)
Usage : 5430007-496
2006 ATV SCRAMBLER 500 4X4 CAB, REAR - A06BG50AA/FA (4999201549920154A04)
2005 ATV TRAIL BLAZER REAR CAB - A05BA25CA/CB (4994739473A04)
Usage : 2632993-496
Usage : 5430007-496
#29
Another quick question. What would cause my rear sprocket to be loose? The sprocket and guard itself is tight but I can turn the whole assembly by hand about an eight inch or more. I'm getting a grinding sound from my chain.
#30
Have to tear it down to get to what's wrong. Could be the hub splines that hold the sprocket tight are stripped. Plus if the sprocket is worn,might as well replace it,front sprocket also and a chain if the links are wobbly or stiff. Can get expensive when parts wear out especially on a 15 year old machine. 2001 Polaris TRAIL BLAZER (A01BA25CA) Rear Housing | Cycle Parts Warehouse If you need a manual to guide you on this here's one for 5 bucks.No major difference between the 2001/2002 Trailblazer except decals...2002 Polaris Trail Blazer 250 Service Manual PDF Download Internal silent chain stretch in the single range gear cases were another problem but fix the obvious problems first.
