Trailblazer 250
Old Feb 27, 2018 | 04:10 PM
  #41
Colors.
Old Mar 9, 2018 | 09:18 AM
  #42
neo27ny's Avatar
I'm ordering parts and I'm wondering which tool to use to pull the flywheel. something preferably cheap or something I can make or rent.
Old Mar 9, 2018 | 12:23 PM
  #43
Harmonic balancer puller. You can rent these at almost all auto houses for a refundable deposit. Here's an example on a 700 flywheel in a dune buggy,but same principle on how to pull the flywheel. You need a 1/2" impact...
Old Mar 9, 2018 | 12:54 PM
  #44
neo27ny's Avatar
I might just buy one now that I know for sure. They can be had for cheap on amazon. I'm replacing the seals. Then I'm going to do a compression test, then possibly a top end depending on the test. I'm stripping it down anyway for a frame up rebuild.
Old Mar 24, 2018 | 09:43 PM
  #45
neo27ny's Avatar
I ordered one. I'm having trouble getting the flywheel off. I'll figure something out. I'm still waiting for my new clutch tool anyway, but the rebuild has officially started today.
Old Mar 25, 2018 | 08:11 AM
  #46
If a flywheel is hard to get off use a little heat from a propane torch around the center of the flywheel and often times it will pop off while under pressure.
Old Mar 25, 2018 | 02:18 PM
  #47
neo27ny's Avatar
Yea I been but I've been scared of the heat around that area. I broke the bolts I bought. I'm thinking about tapping them out to an 8mm bolt see if that helps. Those 6mm bolts were stretching like rubber. I tried both hand tools and air impact...I'll get it lol.
Old Mar 25, 2018 | 03:08 PM
  #48
Use grade 8 bolts,put it under pressure and use plenty of heat around the crank shaft. Tap the end of the puller bolt straight on a couple times. Flywheel should pop off.
Old Mar 26, 2018 | 12:28 AM
  #49
user493's Avatar
Moto Psycho
Sometimes cheap imported bolts will be marked grade 8 when they're really grade 5, or grade 5 when they're really grade 2. If they have both U.S. and Chinese bolts at the store, get the American made no matter what they cost. A little pocket change can make a big difference in what you get. In metric sizes it looks like Class 10.9 is ~= to grade 8, and Class 8.8 would be in the neighborhood of grade 5.
Old Mar 31, 2018 | 09:34 PM
  #50
neo27ny's Avatar
I finally got it. What's the thread size and pitch on the crank and flywheel nut?
