2001 scrambler 500 x worth it
No big deal on the silent chain. Less than 40 bucks. More trouble to pull the gear case out of the frame than to change one if it's stretched. I wouldn't let that be a deal breaker. You can tell reall quick if it has streched. It'll make a grinding or slipping noise from the gear case. Pull up to a tree and put a load on the front bumper. If it grinds but tires don't moved,then the chain needs to be replaced.Plus don't over look a worn outer front sprocket and the drive chain.Item#38 on the chain on the parts break down.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Thanks everyone for your input. I'll be sure to keep ya informed.
#15
So it is the front sprocket. Its got a 13 on it right now. I do not care about top end, more so low torque. Suvgestions on which combo to go with?
#16
According to the parts list stock is a 12 tooth front,36 rear. Sounds like someones already changed the front to get more speed. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Several different sprocket/chain combos on ebay with mostly 13 and 36,a couple with 12/36. You could check Sunstar and JT sprockets as they supply most of the after market sprockets. Same size for the Scrambler 4x4 on front and rear,but JT does offer other sizes. If you want more low end you could drop back down to a 12 and 38 for the rear,or 13/38,plus you can go all the way up to a ridiculous 43 rear.Could pull a stump,but would have very little top end..JT Sprockets: Catalogue
#17
Well replaced front sprocket and it's still kind of slipping I would call it. Not as much but when you really give it throttle it does it. I'm really hoping it's not the splines in the shaft that connects to the front sprocket. Could it be the belt? Anyone have any other suggestions?
Anyone have a pdf manual for this machine? Or could give me the torque specs on the rear 4 bolts I had to loosen to tighten the chain?
#18
Rear eccentric pinch bolts are 60 ft pounds.Rear caliper mounting bracket bolts 12 foot pounds. Free manuals are hard to find,but here's a 2002 Scrambler 500 manual that's basically the same for 5 bucks.2002 Polaris Scrambler 500 Service Manual PDF Download Or a 2001 for $9.50.https://www.payloadz.com/cart/Default.aspx
