She quite on me today ...
Old Jun 21, 2016 | 10:12 AM
bthrel's Avatar
Default She quite on me today ...
2004.5 Sportsman 500 HO
Was heading out to check corn feeders, right before I left the road, slowed down, EBS kicked in, started sounding strange, then came to a stop and died...
Got her back home, had spark at the plug, fuel tank 1/2 full, but won't start.
Pulled line from fuel pump to carb, cranked over and no pulse or stream of fuel.
So is it a good assumption that the fuel pump failed? I have one on order, but just wondering if there is anything else to check? looking it looks like to me that the pulse line comes from the intake in front of the carb, could anything else besides the pump and leaky pulse line cause the no fuel issue?
Thanks
Brian
Old Jun 21, 2016 | 10:25 AM
Check main vacuum line from pump to carb for damage,plus you can pull this line off at the carb,suck on the tube or use a mityvac. If no fuel out the line to the carb more than likely the pump has trash in it or a diaphragm is damaged. Plus check the fuel valve itself. They can stop up and not allow fuel to go to the pump to begin with. Fuel flow is from the tank to the fuel valve,from the fuel valve to the pump and then to the carb.
Old Jun 21, 2016 | 10:28 AM
bthrel's Avatar
Thanks for the tips OPT, I'll post back once I get the pump and perform the other two checks ... My paranoia was making me think something more catastrophic could have happened.
Brian
Old Jun 21, 2016 | 10:43 AM
bthrel's Avatar
Just checked fuel valve, flows fine .. pump arrives tomorrow
Old Jun 22, 2016 | 02:31 PM
bthrel's Avatar
Thumbs up Issue resolved
Installed new fuel pump and all is good...
Thanks
Brian
Old Jun 22, 2016 | 02:36 PM
Wish all problems were as easy to solve as this one..
amalota
Feb 5, 2016 01:45 PM
keeperstweed
Jan 21, 2016 11:14 AM
TULLEY366
Aug 31, 1999 09:49 PM
Robert Venable
Aug 4, 1999 11:36 AM
