my atv wont start
Old Oct 8, 2016 | 09:19 AM
  #61
95scramblerruben1033's Avatar
great
THANKS OPT
Old Oct 16, 2016 | 08:39 PM
  #62
ok guys well i it was a success my complete engine overhaul was completed today, well I have been finished with the engine part of it but i finally got everything all put back together today and she's a purring thanks to everyone that helped me out on this thread appreciate u guys especially OPT.
THANKS ONCE AGAIN
RUBEN
Old Oct 17, 2016 | 06:31 AM
  #63
Hope she lasts a good long while now..
Old Oct 17, 2016 | 11:37 AM
  #64
yeah me too OPT!!! this time around i am running her rich on the oil side.
RUBEN
Old Oct 17, 2016 | 12:09 PM
  #65
Contrary to what a lot of people think more oil to gas ratio doesn't help that much. In fact too much oil and you loose power,foul plugs,not getting the benefit of the octane you're using. The oil pumps were metered at a 50/1 ratio from the factory. If you're premixing then 40/1 is plenty sufficient,36/1 is the max I'd go on a stock engine with a good synthetic oil. Milled heads and cylinders which raise compression,ports opened up and polished,then you could consider going to a richer oil to gas mixture along with a possible jetting change. Plus the compression ratio on a stock 400 engine is only 6.9:1 which is fairly low compared to a lot of the racing machines out there.
Last edited by old polaris tech; Oct 17, 2016 at 01:13 PM. Reason: Compression ratio
Old Oct 17, 2016 | 04:51 PM
  #66
okay thanks opt
razman_07
Mar 13, 2016 04:06 PM
TaoTao110D
Jan 21, 2016 01:23 AM
lakotacr
Jan 23, 2001 10:10 PM
RidE
Oct 12, 1999 12:30 AM
Robert Venable
Aug 4, 1999 11:36 AM
