New to me 2000 Sportsman 500 No tranny fluid???
Any good synthetic oil from 0w40,5w40,5w50 is sufficient in most cases. No wet clutches to worry about and you really have a multitude of oils to choose from.Same thing on oil filters. A lot of oil filter brands that cross over from the oem filter.https://www.google.com/url?sa=t&rct=...nm9RDEMWs89wGA
on
Thank you Very much
1of7627
Polaris ATV Junkie!
Member #4155 Join Date: Apr 2010
Feedback Score: 0 reviews
On consideration not mentioned often is the use of a larger or longer body filter instead of the stock size. There are advantages in both the amount of filtration media and lower internal restriction which could result in the bypass valve being called into play a bit less often.
The stock filter is about 2.5 inches long and the common numbers used have been listed in this thread already. This next group are about 3.25 inches long and have the same media (but more of it) and the same bypass valve specs as the shorter ones. I recommend you use the longer filter if you have clearance for it. Unfortunately, my machines (08-09 mid-size Sportsman 400 HO) have a frame rail running just outside the filter and there's not enough room to get the longer filter in. Your method may vary.
3.25" filter list:
Purolator Pure One PL14610
Mobil 1 M1-110
Bosch 3323
WalMart SuperTech ST7317
AC Delco PF-2057
Carquest 85356
Carquest Red B4620
Castrol 7317
Fram Double Guard DG7317
Fram PH7317
If you use a brand other than one of these, you should be able to cross reference one of these to a comparable one in your brand. (I'd use the Purolator Pure One PL14610 if it fit.)
EDIT: Of course, the larger filter will alter the overall oil capacity slightly.
__________________
POLARIS 3084963 - Alternative oil filters
Replacement oil filters for POLARIS 3084963:
1of7627
Polaris ATV Junkie!
3.25" filter list:
Mobil 1 M1-110
Bosch 3323
AC Delco PF-2057
Carquest 85356
Carquest Red B4620
Castrol 7317
Fram PH7317
__________________
- AC-Delco PF2135
- AMSOIL EAOM103
- ARCTIC CAT 3201-044
- ARCTIC CAT 3201-451
- AUTOEDGE AL6017A
- Baldwin B1400
- Baldwin B7285
- CARQUEST 85358
- CARQUEST 85365
- Champ PH2876
- Champ PH7015
- Champ PH7028
- DENSO 115010-5390
- Donaldson P502067
- EMGO 10-26920
- EMGO 10-82230
- EMGO 10-82251
- Fleetguard LF3925
- Fram PH6017A
- HASTINGS B7285
- HASTINGS LF113
- HIFLO HF198
- HIFLO HF204
- HIFLO HF303
- Honda 15400-P0H-305
- Honda 15400-P0H-305PE
- Honda 15400-PFB-004
- Honda 15400-PFB-007
- Honda 15400-PFB-014
- Honda 15400-PJ7-015
- Honda 15400-PLM-A01PE
- Honda 15400-PM3-405
- Honda 15400-POH-305
- Honda 15400-POH-305PE
- Honda 15400-ZJI-004
- Honda 15400-ZW4-003
- Honda 15410-MCJ-000
- Honda 15410-MCJ-003
- Honda 15410-MCJ-505
- Honda 15410-MFJ-D01
- Honda 15410-MM5-013
- Honda 15410-MM9-003
- Honda 15410-MM9-013
- Honda 15410-MM9-405
- Honda 15410-MT7-003
- K & N KN-198
- K & N KN-204
- K & N KN-303
- K & N KN-303C
- KAWASAKI 16097-0002
- KAWASAKI 16097-0003
- KAWASAKI 16097-0004
- KAWASAKI 16097-1058
- KAWASAKI 16097-1061
- KAWASAKI 16097-1063
- KAWASAKI 16097-1064
- KAWASAKI 16097-1066
- KAWASAKI 16097-1067
- KAWASAKI 16097-1068
- KAWASAKI 16097-1070
- KAWASAKI 16097-1072
- Kubota 15853-32430
- LUBER-FINER PH2876
- LUBER-FINER PH7015
- LUBER-FINER PH7028
- Mann Filter MW64
- MELROE 6671057
- MERCRUISER 35-822626
- MERCRUISER 35-822626Q04
- MERCRUISER 35-822626Q1
- MERCRUISER Q03
- MERCURY 35-8222626Q03
- MERCURY G590000-G760299
- MERCURY G760300-1B226999
- MERCURY P086824-P325499
- NAPA 1358
- NAPA 1365
- NAPA PS1358
- Nissan 3R0076150M
- Parts Master 61358
- POLARIS 2520799
- POLARIS 2540086
- POLARIS 3084963
- POLARIS 3089996
- Purolator ML16817
- Purolator ML16819
- ROBIN 2576730111
- SIERRA 18-7902
- SIERRA 18-7909
- SIERRA 18-7910
- SIERRA 18-7911
- SIERRA 18-7911-1
- SIERRA 18-7913
- SILVERLINE 21358
- STP PH7028
- Suzuki 16097-1072
- TOHATSU (Marine) 3R0076150M
- TRIUMPH MOTORCYCLE T1210200
- TRIUMPH MOTORCYCLE T1210444
- WARNER PH7015
- WESTERBEKE 30220
- Wix 51358
- Wix 51365
- YAMAHA 3FV-13440-00
- YAMAHA 3FV-13440-00-00
- YAMAHA 3FV-13440-10-00
- YAMAHA 5DM-13440-00
- YAMAHA 5GH-13440-00
- YAMAHA 5GH-13440-00-00
- YAMAHA 5GH-13440-10-00
- YAMAHA 5GH-13440-20-00
- YAMAHA 5GH-13440-50-00
- YANMAR 124450-35100
on
Is there a bigger filter to use than the Amsoil filter I used this time?
This is what I am using for filter and fluids.
EA15K13-EA
Absolute Efficiency Oil Filter
$12.05 $12.05
AUDT QT-EA
Synthetic ATV/UTV Transmission & rear Differential Fluid
$9.80 $9.80
AUFD QT-EA
Synthetic ATV/UTV Front Drive Fluid
$10.50 $10.50
AFFQT-CA motor oil
Formula 4-Stroke 0W40 Power Sports Synthetic Motor Oil
EA15K13-EA
$12.05 $12.05
AUDT QT-EA
$9.80 $9.80
AUFD QT-EA
$10.50 $10.50
AFFQT-CA motor oil
You're already running a good filter that's rated for 15,000 miles. Either it or Wix are two of the best rated ones out there. As far a larger filter,I don't know of any others than the cross reference list of filters and don't know if one would have any better filter media than what you have now.That's more important than size.
#15
on
I try to run Amsoil in everything since sometime in the 90's.
I've had great longevity running it. Even with extended oil changes on my diesels with bypass filters
I run mostly Amsoil, Baldwin or Mobile 1 filters as Wix isn't as easy to get here.
I'll just be happy with what I'm running. But I always run as big a filter as I can get - as long as it meets the specs
bonaro
04-09-2021 04:01 AM
reezy
02-21-2016 06:31 PM
