sportsman cv boot
Old Oct 4, 2016 | 02:38 PM
trouttracker's Avatar
Default sportsman cv boot
I have a 2004 sportsman 700 and trying to change the front inner cv boot. I have the axle out but cannot find the locking ring like there is on the back am I missing something or how do you get the axle out of the cv joint.
Old Oct 4, 2016 | 03:05 PM
Unless I'm mistaken just whack the cv joint housing with a brass hammer and it should come off the shaft and the clips stays on the shaft.. Don't recall front drive shafts having the spread apart circlip like the rear have.2004 Polaris A04CH68AC SPORTSMAN 700 (A04CH68AC/AF/AH/AJ/AT/AV) Front Drive Shaft | Cycle Parts Warehouse
Old Apr 28, 2017 | 10:29 PM
grizzsara's Avatar
Hope you had luck with this - did you end up having to replace the whole joint? ACV has some good parts if that's the case. Hope you figured it though. It's not the most graceful process, that's for sure.
antileno
Aug 24, 2016 10:27 PM
hoser223
Aug 24, 2016 02:43 AM
champ198
Aug 22, 2016 04:57 PM
mtnxtreme
Aug 11, 2016 11:53 AM
Ron Hofstrand
Jul 10, 2016 07:53 AM
