2000 polaris magnum 325
Old Mar 23, 2017 | 02:32 PM
  #31
Fjdm's Avatar
And this is the key swicht they have wired in
Old Mar 23, 2017 | 03:46 PM
  #32
Sure this machine wasn't stolen? Both the solenoid and ignition switch look like something that came off a lawn mower. If you want to fix it right buy an oem switch and solenoid like the one I posted. You can still probably find the right connector here for the switch.Motorcycle Connectors If not look for any cheap 2000 model Polaris harness on ebay. You can use the connectors off it.If you need help the manual can guide you.https://www.tradebit.com/filedetail....air-manual-all
Old Mar 23, 2017 | 03:52 PM
  #33
Fjdm's Avatar
Yes I'm positive it wasn't stolen I know everyone that had it its just been fixed totally $igg rig to work
Old Mar 29, 2017 | 07:47 AM
  #34
Fjdm's Avatar
Ok so I need a new left handle bar switch what years will work for me for this 2000 magnum.
Old Mar 29, 2017 | 01:55 PM
  #35
Taking a chance on used electrical parts,but here's the part number and models that share the same left control switch.
Usage : 4010262 Control Switch
Year Product Model Assembly
2001 ATV 325 MAGNUM 2X4 HDS HANDLEBAR - A01CB32AA (4963966396C001)
2001 ATV MAGNUM 325 2X4 HANDLEBAR - A01CB32AA (4963966396C001)
2001 ATV 325 MAGNUM 4X4 HDS HANDLEBAR - A01CD32AA (4964026402C001)
2001 ATV MAGNUM 325 4X4 HANDLEBAR - A01CD32AA (4964026402C001)
2001 ATV MAGNUM 325 4X4 MOSE HANDLEBAR - A01CD32AA (4964026402C001)
2001 ATV XPLORER 400 HANDLEBAR - A01CG38CA (4963916391B010)
2001 ATV 500 MAGNUM 500 HDS HANDLEBAR and HEADLIGHT POD - A01CD50AA (4964196419B013)
2001 ATV MAGNUM 500 HANDLEBAR and HEADLIGHT POD - A01CD50AA (4964196419B013)
2001 ATV SPORTSMAN 400 HANDLEBAR and HEADLIGHT POD - A01CH42AA (4964436443B013)
2001 ATV SPORTSMAN 500 DUSE HO HANDLEBAR and HEADLIGHT POD - A01CH50AA (4964466446B013)
2001 ATV SPORTSMAN 500 HO HANDLEBAR and HEADLIGHT POD - A01CH50AA (4964466446B013)
2001 ATV SPORTSMAN 500 RSE HO HANDLEBAR and HEADLIGHT POD - A01CH50AA (4964466446B013)
2001 ATV WORKER 500 HANDLEBAR and HEADLIGHT POD - A01CH50AA (4964466446B013)
2001 ATV SPORTSMAN 500 DUSE HANDLEBAR and HEADLIGHT POD - A01CH50AD (4960026002B013)
2001 ATV INT'L BIG BOSS 6X6 HANDLEBAR and HEADLIGHT POD - A01CL50AA (4964586458D001)
2001 ATV SPORTSMAN 6X6 HANDLEBAR and HEADLIGHT POD - A01CL50AA (4964586458D001)
2001 ATV DIESEL HANDLEBAR and HEADLIGHT POD - A10CH46CA (4964376437B009)
2001 ATV SCRAMBLER 500 2X4 HANDLEBAR/HEADLIGHT - A01BA50AA (4963716371B005)
2001 ATV SCRAMBLER 500 4X4 HANDLEBAR/HEADLIGHT - A01BG50AA (4963766376B008)
2001 ATV TRAIL BOSS STEERING - HANDLEBAR - A01AA32AA (4963816381B006)
2001 ATV TRAIL BOSS 325 SE STEERING - HANDLEBAR - A01AA32AA (4963816381B006)
2000 ATV 325 MAGNUM 2X4 HDS HANDLEBAR - A00CB32AA (4949354935B011)
2000 ATV MAGNUM 325 2X4 HANDLEBAR - A00CB32AA (4949354935B011)
2000 ATV 325 MAGNUM 4X4 HDS HANDLEBAR - A00CD32AA (4949404940B012)
2000 ATV 325 MAGNUM 4X4 HDS II HANDLEBAR - A00CD32AA (4949404940B012)
2000 ATV MAGNUM 325 4X4 HANDLEBAR - A00CD32AA (4949404940B012)
2000 ATV 500 MAGNUM 4X4, HDS HANDLEBAR and HEADLIGHT POD - A00CD50AA (4954885488B011)
2000 ATV 500 MAGNUM 4X4, HDS II HANDLEBAR and HEADLIGHT POD - A00CD50AA (4954885488B011)
2000 ATV MAGNUM 500 HANDLEBAR and HEADLIGHT POD - A00CD50AA (4954885488B011)
2000 ATV MAGNUM 500 EB HANDLEBAR and HEADLIGHT POD - A00CD50AA (4954885488B011)
2000 ATV XPLORER 400 HANDLEBAR and HEADLIGHT POD - A00CG38CA (4954875487B013)
2000 ATV SPORTSMAN 335 HANDLEBAR and HEADLIGHT POD - A00CH33AC (4959905990B013)
2000 ATV DIESEL HANDLEBAR and HEADLIGHT POD - A00CH46CA (4954785478B011)
2000 ATV SPORTSMAN 500 HANDLEBAR and HEADLIGHT POD - A00CH50AA (4954805480C001)
