New Bike!
#52
Call DB first as they do show the part#stator for your model listed in Polaris Parts and Partzilla(4010911). Plus you should have a crank position sensor coming out of the bottom of the flywheel cover that takes the place of the pick up coil.That stays.
#56
Just get you one of these.Makes short work of pulling,installing springs without tearing your fingers up. Most auto stores have them. If not listed as a spring puller,they may be listed as a dent puller. That's where the idea came from.
#58
I now have one of those tools as well. Couple years ago, putting my exhaust back on my snowmobile, I stabbed myself right in the eye with a needlenose. I lucked out big time, and never had any complications from it. Kind of scary though.
#59
Man,glad you're ok.. I've busted knuckles,torn up fingers but nothing quite that bad.. Back in the "olden" days around 86-87 I'd buy dent pullers off the tool trucks and made the hook have a little sharper bend for the springs. Worked great. Over time other techs had the same idea and places like Motion Pro jumped in on it and made those funky little wire loop spring pullers. Still killed your hand,but they at least worked. Then someone else just converted over dent pullers and the rest is history. I sure remember the old green handled pullers in this picture.I'd get a couple different lengths and alter them for easy and hard to reach springs.
#60
Wow. I'm glad you're okay. I cut my eye on cement when I was a baby or toddler and I was lucky too. I think the scar finally faded away but I had a little red mark on my eyeball for decades. The only thing I stabbed lately was my fingertip, about a week ago. I was poking holes in these air-filled plastic packaging things that look like little pillows. I let the air out so they don't fill up my trash can. I was thinking, "I better be careful so I don't , *&^%$#@!"
I was more careful today when I got another package. P.S. I made handles for my pocket chainsaw out of pieces of a broom handle and a couple of nails that I bent into the same shape as the spring puller. I had washers on the nails so the heads wouldn't wear a hole in the wood. They might work as a spring puller too but an actual spring puller is thinner and smoother than the nails. Supreme Products, Inc. Maker of The Pocket Chainsaw
