Rpms reading 0
Old Sep 18, 2017 | 01:50 PM
  #51
lph008's Avatar
Anything I need to watch out for or do other than what you said? It's been a few years since I replaced a stator. Will a steering wheel puller work?
Old Sep 18, 2017 | 02:06 PM
  #52
You can get a heavy duty harmonic balancer puller kit at most major auto houses with a refundable deposit. Check for any oil leaks coming from the stator plate. If that's ok,just replace the stator. Here's a good video on pulling a flywheel. On a 700 in a dune buggy but same procedure.
Old Sep 20, 2017 | 12:14 PM
  #53
lph008's Avatar
Found the culprit!!! New stator will be here Friday.
Old Sep 20, 2017 | 12:16 PM
  #54
lph008's Avatar
what do you recommend using to clean the flywheel and case? Scotch brite and brake cleaner?
Old Sep 20, 2017 | 02:04 PM
  #55
Since the old stator is junk and removed you can use the stronger brake cleaner rather than electrical contact cleaner. Just don't spray any directly on the seal(#8) on the stator plate.Scotch Brite is fine to use on the engine case and cleaning the flywheel inside and out.
Attached Thumbnails Rpms reading 0-597a801db5161bb85a3a0f982618a88582c5cfb6.png
Old Sep 20, 2017 | 03:38 PM
  #56
lph008's Avatar
is there any type of lube I can use on the Bendix and also how do you clean The Recoil rope? I have also noticed on quite a few sportsmans that after you start the motor with the electric start you can hear a chattering which I'm assuming is probably a weak spring on the Bendix? This one is currently doing that and it sounds. Awful LOL
Old Sep 20, 2017 | 04:40 PM
  #57
You can clean the recoil rope by pulling it all the way out,clamp the rope at the housing nipple and spraying the rope with brake cleaner.Removes a lot of dirt and oil residue. When dry let it recoil back in. Replace the starter bendix as now is the best time to do it. Cheap on ebay or amazon.
Old Sep 21, 2017 | 11:32 PM
  #58
lph008's Avatar
Well I got the stator today, just put it in abd im good to go!!!!! Rpms now read when idling and I'm not overcharging anymore. Thanks OPT I have another happy customer with your help
Old Sep 22, 2017 | 03:55 AM
  #59
Rpm signal is from the stator through the ecm. Glad that's working now with the new stator along with it charging correctly.
Deercutter
Feb 10, 2005 09:03 PM
