Rpms reading 0
#31
Have you had this done or checked it yourself? Voltage isn't always an indicator of battery condition..https://www.youtube.com/watch?v=3QiKyjWWiRo
Do you habe any idea why the rpms don't read at idle but work when I throttle?? I'm starting to think they might be the cause. Maybe a bare wire or something. Not sure where the speedo gets the rpm from
#32
yes I've done the load test twice already. I even had lights on and cranked it and it dropped just below 11 volts and low 12s when just cranking and no lights.
#33
Stator sends the 3 yellows to the ecm module,ecm sends signal to the speedo y/r pin. Go through the speedo pin test chart in the manual. Problem may be there or in the speedo display itself. 2005 Polaris Sportsman 500 Service Manual PDF Download
#34
Well I'm getting out early so I am going to try testing the speedo and those wires I might just buy a cheap or used stator. that's really the only other thing that could be causing it correct? The machine is in close to excellent condition but you never know there could be a wire that is bad not even sure if that would cause this
#35
Same thing with a new ecm and battery supposedly checks out ok,then sounds like that's all you have left to replace is the stator. Beyond that I'm about toast on this machine..
#36
. I know either way its not the way to go but wouldyou recommend a cheap stator or a used oem stator? I'll let the owner decide if they want to go with a new oem if it ends up fixing the issue afterwards down the road. I'm taking battery back up to have it properly load tested just to be sure. I'm also going to see if I can rent a better meter.
#38
[QUOTE=lph008;3373112]I'm completely over it lol. Last 3 sportsmans that I've worked on all had electrical issues. Whether it was tps, or shorts. Stress is overkill. I need able to figure them out with your help eventually. Don't give up on me noe OPT 😂
. I know either way its not the way to go but wouldyou recommend a cheap stator or a used oem stator? I'll let the owner decide if they want to go with a new oem if it ends up fixing the issue afterwards down the road. I'm taking battery back up to have it properly load tested just to be sure. I'm also going to see if I can rent a better meter.[/QUOTE
just had the battery low tested had to go to three places the young people don't know how to do it apparently. anyway it tested good. Couldn't get a auto meter though.
#39
Then give this one a shot if the owner agrees to it.STATOR POLARIS SPORTSMAN 500 HO 2005 2006 2008 POLARIS ATV MAGNETO | eBay
#40
Then give this one a shot if the owner agrees to it.STATOR POLARIS SPORTSMAN 500 HO 2005 2006 2008 POLARIS ATV MAGNETO eBay
So just to clarify...short to ground test shouldn't go to 0 correct?
