Polaris 250 Trailblazer - Spark only with pull rope
Old Feb 16, 2018 | 04:19 PM
Originally Posted by Trailblazer Hater
This is what my stator and flywheel looks like. How do I move the exciter coil outward toward the magnets inside the flywheel? I assume you guys are talking about other Polaris models with the external pick up when you say "a simple tap on the bracket to move it closer to the flywheel..." Right?
Yes we were talking about the later model "pickup coil" mounted outside of the flywheel on the stator plate not the exciter coil on the older ones like yours has. As far as moving it further? I'd match it up the the oem plate and see if it's the actual size of the exciter coil itself(possibly smaller than the oem exciter) that may be the cause of the problem,or if there is a physical difference on the hole distance on the plates. Possible that you could transfer the lighting coil and exciter to the oem plate if there is a difference.
Old Feb 25, 2018 | 06:24 AM
Trailblazer Hater's Avatar
SOLVED - RESOLVED
This is the stator I bought off ebay: https://www.ebay.com/itm/Stator-For-...53.m2749.l2649
Sold by racetechelectric
It is not a Caltric as I'd originally thought. DO NOT BUY THIS PRODUCT OFF EBAY. It is junk. I bought a used OEM Polaris Stator and that fixed my issue immediately. I have all kinds of spark now whether using the electric start or the pull rope.
I cannot speak for the Caltric part, but this eBay stator is a piece of garbage. The company was quick to respond to my issues, but.....save your money.
Thank you Old Polaris Tech. You rock!
Old Feb 25, 2018 | 09:03 AM
I'm not gonna trash any particular company as more than likely the stator they supplied to you was made in some sweat shop in Asia somewhere. Same for some Caltric parts,some are hit or miss on electrical and mechanical parts such as carbs.Some have had good luck with their parts. Problem is that there are too many aftermarket places out there now offering cheap parts that a lot of people can't resist.Very little quality control,using inferior materials,cheap labor,many of these people probably not trained/qualified and a lot of times that results in the final product that ends up in the customers hands being faulty.Possibly a replacement stator from them may have worked,but glad you have it solved with a used oem part. Plus you can look real close at that stator you posted a link for. The individual lighting coils looked like they were hand wrapped instead of the more uniformed machine wrapped coils found on better quality stators. Probably the same for the exciter coil,cheap wiring,less of it then wrapped up.
Old Feb 26, 2018 | 07:41 AM
https://www.ebay.com/usr/racetechelectric?rmvSB=true got ahold of me and they are giving me a refund! I had to send them a pic of my multimeter taking a measurement of the exciter coil and they authorized a refund. So far, it looks like pretty good customer service.
Old Feb 26, 2018 | 09:02 AM
  #15
Most reputable companies will try to work with you and like I mentioned another stator from them may have worked ok with no problems.
Old Feb 26, 2018 | 12:25 PM
  #16
user493's Avatar
Moto Psycho
A lot of companies have a no return, no refund policy when it comes to anything electric. I guess sometimes you get lucky. Having proof sure helps.
jacob_royer
Mar 20, 2011 07:45 PM
brazos49
Nov 20, 2008 11:18 AM
captainelectric
Sep 19, 2008 11:15 PM
jhuff1
May 29, 2008 01:25 AM
DJ ZERO
Mar 5, 2008 08:29 AM
