Polaris Magnum 330 - No start. Detailed info inside :)
You may be surprised what the right kind of glue can do. As one guy says online, "It is not widely known by the general public that aircraft wings are usually glued on to the plane, not rivoted, bolted, or using some other mechanical fasteners." That's an interesting way to spell "riveted".
She runs!
The coil was fine. it wasn't really cracked, it was just kind of pried away from its metal mounting bracket.
Gorilla glue, if used judiciously, is amazingly strong when bonding plastic to metal. I left it overnight clamped (gently but firmly) in vice grips and then cleaned up all the overflow in the morning, there wasn't much.
I am sure that the bond is stronger than it was originally.
Once I put it all back together, I had strong spark and she fired right up.
And, I now have adjusted valves, rebuilt carb, new fuel filter and pump, and new fuel lines! And the pull starter too!
#15
I know I'm dredging up an old thread but I have a specific question along this line.
New carburetor, new fuel lines. It ran beautifully for several days and all of a sudden won't start.
Changed the spark plug. I'm assuming I'm getting spark but I have an inline tester coming to make sure.
Took the fuel line off the pump that goes to the carburetor. It shoots gasoline out when turning the engine over.
However, the plug was dry when I changed the old one out. Should it be at least a little damp with gasoline? If not, I guess I have to take this Beast apart again
#16
crethem
01-21-2015 09:14 AM
