Reverse AWD finnicky
Old Sep 26, 2018 | 06:01 PM
Sugarkryptonite's Avatar
So after changing the hub oil then going for a full day ride on Sunday, the problem seems to have resolved. AWD worked in reverse every time I had to use it. AWD got stuck a couple of times, just had to reverse then go forward again for it to disengage.
Old Sep 26, 2018 | 07:56 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
And that's why I asked in my first reply, "What kind of hub fluid are you using?" I'm glad to hear it worked out for you. My '97 Sportsman 500 got stuck in 4x4 a few times. Once was when I was in 4x4 backing up the side of a hill to turn around.
Old Sep 26, 2018 | 07:58 PM
polman500's Avatar
Yep, they MUST be changed regularly to keep working right. You should probably change it again to really flush it out good.
chikester
Oct 9, 2018 12:13 PM
trbojet1
Oct 12, 2017 04:33 PM
650bomber06
Oct 11, 2010 08:03 PM
bbrc
Jan 17, 2005 10:25 PM
andyems
Jan 23, 2002 08:02 PM
