Rear drive shaft
Old Oct 8, 2018 | 06:44 PM
Thomas14's Avatar
Default Rear drive shaft
I am needing help removing my rear drive shaft. I cant seem to get pin out! Tried putting a drill bit in it and hitting with a hammer and now the bit is stuck. Any ideas?
Old Oct 8, 2018 | 07:26 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
Penetrating fluid. Let it soak in overnight.
Old Oct 9, 2018 | 06:40 AM
scootergptx's Avatar
Supersock
Hired Gun!
Had a bike I couldn't get the drive shaft apart. Sprayed it down really good with some PB Blaster and let it set overnight. Next day, one light tap and it fell apart.
Old Oct 10, 2018 | 06:14 PM
Thomas14's Avatar
Default Thanks
Got the pin out...now cant get yolk to come off diff. I have soaked it for about 24 hours or more and it's not moving at all. I toke diff off to be able to get to it better but no luck. I thought it just slides right off but my case. Any help here
Old Oct 10, 2018 | 07:46 PM
94harley's Avatar
Air hammer is useful. Just try not to damage anything. Probably rusted on. The shock from the hammer cycles can actually break rust free. Have seen it several times. Most people( in my area anyway) went aware there was a zero on there anyway, so the get rusted.
Old Oct 12, 2018 | 11:26 PM
Thomas14's Avatar
We got it finally! We are putting everything back together now the axel nut wont start on spindle. No cross thread at all. No damage that I can see. It will turn once then get tight like it wants to cross thread. Any ideas here?
jdrockton
Jul 16, 2018 02:53 PM
welshy
Mar 9, 2005 05:32 PM
tguil
Oct 22, 2004 08:38 AM
Rudnik
May 3, 2000 11:05 PM
GreggWNY
Aug 22, 1999 02:29 PM
