1995 Polaris scrambler 400L 4x4
So I just rescued my Polaris scrambler from under a tree where it never moved except when they hit it with a plow truck. Anyways I got it running and lost the bearings after about 20 hours.Now I just rebuilt the engine and I had a broken skirt rusted by bearing now my oil injection wasn't hooked up and I'm wondering if I should bother hooking it up I've just been mixing 40:1 seems safer to me also I put a natural piston in it will that skirt break
Lot of controversy on the oil pump being hooked up or not. MY opinion, hook it up. I have only seen 3 fail in the 30 years I've been doing this. 2 of them were customer faulted failures too. A lot of people like to unhook it and pre-mix. I dont worry about either, both ways work fine. The oil pump(if your wondering) did NOT cause the skirt to break. The 350 and 400 2 strokes didn't have an issue of if the piston will break, they had an issue of WHEN they will break. It is basically unavoidable unless you change the piston. Newver used namura pistons so no info from me there. WE always used wiseco and to date havent had a skirt breakage problem.
hey i just got it running today but it kept going into a high idle and I mean shut it down it would rev right out so I noticed my throttle cable was run down in a funky manner so I'm gonna reroute it tomorrow
Frankenbrute100
Technical and How-To Articles
Oct 23, 2018 11:57 AM
